Pudenz fuse 12V,160A, til ankervinsj i seilbåt
Need help to find Pudenz fuses for 12V, 160A for the anchor winch in my sailboat
Hello, Kjersti. Welcome to Digi-Key TechForum.
May I ask for more details on this fuse? “Pudenz” seems to be a supplier that creates many different types and styles of fuse. Do you know which style you need?
This one might work. Please verify the part with the datasheet below.
Digi-Key Part Number | F10067-ND | |
Manufacturer | Littelfuse Inc. | |
Manufacturer Product Number | 157.5700.6161 | |
Description | FUSE STRIP 160A 48VDC BOLT MOUNT | |
Manufacturer Standard Lead Time | 10 Weeks | |
Detailed Description | 160A AC 48 V DC Fuse Fuse Strip Bolt Mount | |
Datasheet | Click Here |
Thanks for your quick answer
Kjersti
Hi again
This one is for 48V. My sailboat has 12V. Will it work and breake the circuit at the right power then?
Kjersti
Yes it will safely open the circuit at 160A for any voltage less than or equal to 48VDC.
Thank you. We have ordered it now.
Regards Kjersti Apenæs
