Q-KIT(R) Digi-Key Part Number 1939-1103-ND
Manufacturer|[GlobTek, Inc.
Q-KIT(R) do these connect directly from wall to USB input for charging instrument ?
Or is there some other adapter in between ?
They are intended to use with an AC DC Wall Adapter Power Supply, they are a changeable wall adapter plug so your power supply can work in different countries with different outlets.
The compatible power supplies have lots of options for different voltages and different size/type of plugs on your equipment side.
