Question about CSC16AC
------Question for CSC16AC Please Put your question below------
The requirement is for a solution that can support storage of multiple laptop models and enable GC loading or CDD using a centralized (hive-based) methodology. Ideally, this should allow all GC/CDD loading activities to be performed in a single instance with a single master control
Hello fastrack.technologie, welcome to the TechForum! The requirement you are asking about appears to be quite niche. I’d recommend reviewing the datasheet to see if it talks about GC/CDD loading. I am not familiar with “centralized hive-based methodology,” that is a new term to me. You may have to look through the manufacturer’s site too because they offer more resources:
https://www.eaton.com/us/en-us/skuPage.CSC16AC.html#tab-3
The part CSC16AC does not have any technology in it to support GC loading. This part is a steel enclosure with dividers on a shelf and an AC power strip in the base. It can hold up to 16 laptops with a screen size of 15 inches.
