Question About Mating Compatibility of NorComp Connectors (171-050-113, 171-050-213)?
------Question for 171-050-213R031 Please Put your question below------
I would like to confirm the mating compatibility of the following NorComp connector part numbers:
  • 171-050-213
  • 171-050-113
Could you please confirm which cable connector or crimp connector mates with each of these parts?
Specifically, I would like to verify whether:
  • 171-050-213 mates with 170-050-173
  • 171-050-113 mates with 170-050-273
Thank you.
@esto68155 Welcome to DigiKey’s TechForum!
171-050-113Ryy1 and 171-050-213Ryy1 are male and female standard straight D-Sub connectors with 50 posisions of PCB dip solder pins.
For these standard density 50 pos. D-Sub connectors, you can use 170 series standard density crimp & poke D-Sub connectors for cable mount application.
The full part numbers may vary depending on their options, but their formats are 170-050-173LYY0 (Male) and 170-050-273LYY0 (Female).
So, 171-050-113Ryy1 will mate with 170-050-273LYY0, and 171-050-213Ryy1 will mate with 170-050-173LYY0.
Best regards,
Thank you for you quick and clear response.
