Questions About Pomona 1452 and 72938 Specifications and Shipping to Korea
------Question for 1452 Please Put your question below------
I am comparing the Pomona Electronics 1452 and 72938 adapters for pulsed OLED transient electroluminescence (TrEL) measurements.
I would like to ask a few questions:
  1. The 1452 datasheet specifies a nominal BNC impedance of 50 ohms. Is the 72938 also suitable for a 50-ohm pulse signal connection?
  2. What are the main differences between these two adapters? Could you also confirm whether the BNC center contact and outer shield are connected separately to the red and black banana terminals?
  3. The listed prices are KRW 39,176 for the 1452 and KRW 53,691 for the 72938. What would be the total price, including shipping, and the estimated delivery date to South Korea for one unit of each product?
Thank you for your assistance.
Greetings,
The 1452 is equipped with general-purpose binding posts that offer flexibility in exchange for near-zero protection against incidental contact, while the 72938 is equipped with insulated banana jacks of the sort typically found on multimeters.
I would expect both to be equally good (or bad) at maintaining a characteristic impedance, since the entire point of both is to accommodate a change to an unstructured cabling system. Black terminal appears to be BNC shield and red inner conductor for both.
Pricing and delivery times will vary depending on options selected at checkout.
