------Question for CRD200DA12E-XM3 Please Put your question below------
I am currently reviewing the following product in your catalog and would like to confirm its regulatory and quality compliance before proceeding with the purchase:
Part number / SKU: _1697-CRD200DA12E-XM3-ND_________
Product description: ________
| EVAL BOARD FOR CAB400M12XM3 |
____________
Could you please confirm the following points:
REACH compliance
Does this product comply with the EU REACH Regulation?
If so, could you provide the applicable REACH Declaration of Conformity?
Certificate of Conformity (CoC)
Is a Certificate of Conformity (CoC) available for this item?
If available, could you please provide a copy or indicate how it can be obtained?
CE marking
Is this product CE marked, or is it exempt from CE marking?
If CE marked, could you confirm under which EU Directives / standards conformity is declared?
Additional documentation
- Is there any additional technical or compliance documentation available (material declaration, quality statement, datasheet, etc.)?
Thank you in advance for your support.
Kind regards,
Pilar
