Hello rmabry63,
Welcome to the DigiKey TechForum! Are you looking for the blue connector itself or are you looking for the socket contacts that go into the connector?
Regards,
Klint
The socket.
Thank you for clarifying; I checked the information on the connector experts page using the E-TERM384 above. It says the wire is from 14-18 gauge which means an equivalent may exist in the following list:
Rectangular Connector Contacts | Rectangular Connectors | Electronic Components Distributor DigiKey
Unfortunately without knowing the exact connector that they’re associated with, I won’t be able to narrow it down any further, as I was unable to locate any commercial series equivalent for the connector.
Regards,
Klint
Thank you for your reply. I will further identify the associated rectangular connector tomorrow a.m.
Kind regards,
Rob
Details about the C7 TIPM Connector:
Designation: C7 (Blue 70-way or similar variant depending on configuration).
Supplier: TE Connectivity/Tyco is a primary supplier of electrical connectors for Chrysler/Dodge/Ram Totally Integrated Power Modules.
- Connector Part Number: Known as G36C42 (42-Pin Connector) or part of the “Headlamp and Dash” harness, sometimes designated C7-Blue.
I am sorry to say that I to am not able to ID the connector’s manufacturer item number that is being referenced.
“G36C42” does seem to reference an item that matches the blue item you have in the above image. But I was not able to find it on TE’s site.
Thanks for all the help folks. Guess I’m going to have to bite the big one and order the overpriced (Plus $19.00 shipping) item I posted the picture of.
Absolute robbery!
Thanks again,
Rob
