If you’re facing obsolescence challenges with Micron’s Parallel NOR Flash devices, there’s a seamless path forward.
The PC28F256P33TFE from Alliance Memory is a direct replacement for the discontinued Micron model, allowing you to maintain your existing design without costly redesigns or requalification efforts.
Why choose Alliance Memory?
Alliance Memory has acquired the manufacturing rights for Micron’s legacy Parallel NOR Flash families (J3, P30, and P33). This ensures long-term availability and continuity, manufactured using the same proven 65nm process technology you relied on before.
Key Benefits:
Pin-to-pin compatibility with Micron’s original design
No redesign required
Same process technology (65nm) for consistent performance
Long-term supply assurance
Datasheet
256Mb and 512Mb (256Mb/256Mb), P33-65nm
Available here:
Official Continuity Authorization
Available here:
Micron J3/P30/P33 Parallel NOR Flash - Alliance Memory
