Removable plunger/armature?
Looking at a solenoid actuator here - DSTL-0840-05. Just wondering if the plunger is removable? The issue is once the solenoid body is secured into the housing, the clevis hole becomes concealed, thus if the plunger is removable, I could install the clevis first then install the solenoid body.
Thank you for your inquiry and welcome to the community.
The plunger on DSTL-0840-05 is removable.
Thanks Kristof,
So basically the plunger will slide in & out freely if the solenoid isn’t powered on correct?
