Replacement soldering tip for this style of soldering iron
------Question for SL325 Please Put your question below------
To my understanding, this iron is made of 3 parts, the handle, the screw in heating element and the replaceable tip which threads onto the end of the heating element. The question is where to source the replaceable tips for this style iron. I have a few older handles and heating elements with which I’d like to replace the tip component. Thank you for any input you may have!
Welcome to the techForum.
I was able to locate a few good options of tips and will look for others. This should get you a good start on the link below.
Soldering, Desoldering, Rework Tips, Nozzles | Soldering, Desoldering, Rework Products | DigiKey
Thank you
Ryan
Hello Ryan, great on your mighty quick response! After a bit more research it seems these components are part of Apex/Weller’s PL series of irons - 7400, 7500, 7760, 7770. Many options are available and found a number of them within Digikey’s webpages, so all good news! Thank you again, Steve
