Request for Classic PSN/LIC Activation for Keil µVision 5.27 with ARM Compiler 5.06 Update 6
Hello DigiKey Support Team,
I am working on an existing STM32F103 firmware project that was originally built in Keil µVision 5.27 using ARM Compiler 5.06 update 6 / ARMCC5.
I want to purchase the correct Keil MDK-ARM Professional license, but before purchasing, I need confirmation about the activation method and compiler support.
My current Keil µVision 5.27 License Management window supports the classic Single-User License activation method using PSN → LIC. It does not show the newer User-Based License activation tab.
Please help me confirm the following:
  1. Can DigiKey provide or guide me to purchase a Keil MDK-ARM Professional license that supports classic PSN-to-LIC activation for Keil µVision 5.27?
  2. Will this license unlock ARM Compiler 5.06 update 6 / ARMCC5 inside Keil µVision 5.27?
  3. Will this license remove the MDK-Lite linker code-size limitation, so I can rebuild the full STM32F103 firmware project?
  4. If the current license sold is User-Based only, please guide me on the correct legacy/classic license option for Keil µVision 5.27 and ARM Compiler 5.
I have already installed Keil µVision 5.27, and the firmware project is configured to use ARM Compiler Version 5. Without a compatible license/compiler activation, I cannot rebuild or test the firmware properly.
Please route this request to the correct Keil/Arm licensing support team if needed.
Thank you.
Best regards
I hope digikey will respond you here. If they don’t I think you should mail digikey or keil ARM support directly.
@raeesabdullah111 It would be best to contact Keil directly on this issue.. Keil Product Support
We have no control over the key generation or software download.
Regards,
Kindly see Arm Developer’s Wiki on the subject:
QUESTION
How can I switch between different versions/builds of the Arm Compiler toolchain within the MDK µVision IDE?
UVISION: Using different versions of the ARM Compiler
