Requesting custom SiT8209 part number
I’d like to order SiTime part number SIT8209AI-21-XXX-189.300000. Can you please add it to your website?
Correction to my request above — I used ‘XXX’ as a placeholder by mistake. Could you help me build the correct part number instead? I’m looking for something in the SiT8209 series (80-220MHz range), at a frequency of 189.3 MHz. Whatever the correct configuration code should be in place of what I wrote, please let me know the valid part number.
Greetings,
Page 10 of the linked datasheet describes the numbering for the product series. You’d need to chose which values for the remaining options you prefer, and update the placeholder accordingly. The part number configurator on the SiTime site can also be used to compose/validate. Note that the “G” package and 10PPM stability options are not programmable by DigiKey at this time.
I used SiTime’s own Part Number Generator to build a valid part number: SiT8209AI-31-33E-189.300000Y. Could you please add this to your website so I can order it?
Package type should be omitted. I will submit SiT8209AI-31-33E-189.300000. Please check the site in a few business days.
