Right angle specifications
------Question for M24308/23-28Z Please Put your question below------
This part number is defined as mil-grade, right angle, female board soldered 37 pin connection DB style.
The spec that is attached on the web page does not show the right angle part, nor does any of the part number breakdowns define how to make it a right angle part.
@stephen.franks
For the M24308/23-28Z I found the below drawing that would show the right angledness of that item.
ENG_CD_1757836_C.pdf (294.4 KB)
Drawing found from the below page.
1757836-4 : AMPLIMITE D-Shaped Connectors | TE Connectivity
