With gray-coded encoders, it is irrelevant whether A leads B or vice versa. Just swap the channels (e.g. in firmware the GPIO definition) if the sequence is opposite.
Thank you for your assistance. I would like to clarify my requirement regarding the rotary encoder pin arrangement.
The device I have is a closed system, and I cannot modify its firmware or software. The original encoder’s pin arrangement is therefore important for proper operation.
The replacement encoders I have found have their pins arranged as A-C-B, whereas I need an encoder with the pin arrangement B-A-C.
With the A-C-B arrangement, turning the encoder clockwise causes the displayed values to decrease instead of increase. Since I cannot change the software to reverse the counting direction, I am looking for an encoder with the B-A-C pin arrangement to achieve the desired operation without modifying the firmware.
Although I could cut and cross-solder the encoder pins as a last resort, I would prefer to preserve the original configuration and avoid modifying the component.
Could you please confirm whether an encoder with the B-C-A pin arrangement is available, or whether the pin configuration of the encoder you recommend can be supplied in this order?
My apologies, I though you are building a custom scanner HW. If you are on repairing an existing product, it may be possible to find an original replacement encoder.
Please provide good quality photos of the encoder
Please provide the information of the product (maker, product ID, etc.)
In addition, kindly provide the description of the actual problem that you are facing. If the issue is erratic response while the dial is rotated, the first thing to try, before replacing the encoder, is to apply some contact cleaner treatment.
