S82J-15024DD is a power supply from Omron Automation and Safety, which has been made obsolete by the manufacturer. A possible substitute for this part is Omron’s part number S8FS-G15024CD. This part is slightly smaller than the original part number, it has a wider temperature range and a better efficiency rate. The datasheets for each part should be compared to verify this part as a suitable part for the application.
