------Question for SC1967 Please Put your question below------
Pls help to check and verify why your SC1967, from website showing CM5 = SC1595 instead.
The attached datasheet also showing as CM5-SC1595
Can you pls help to confirm.
I checked on the manufacturers website and it looks like they refer to this as a CM5 as well. Although checking their datasheet i was unable to find SC1967 in the list of parts. I’m wondering if they have not updated it to include SC1967 yet.
RP-008182-DS-2-cm5io-datasheet.pdf (5.5 MB)
From our record, SC1967 as per image. Can you help to verify it.
Hello zuerma.othman,
It appears that the manufacturers page linked HERE, shows that SC1967 would confirm that it is the Compute Module 5 IO Board.
