Screw/nut P/N# for M83513/04-H03C (ITT)
Hi
may we know the screw/nut P/N# for M83513/04-H03C (ITT)
Anita Mai
Welcome to the DigiKey TechForum. There is no specific screw/nut listed as an accessory for this part. Choosing the correct screw size will depend on the thickness of the panel this will be mounted to. The diameter of the hole on the mounting flange is 3.68mm to 3.81mm, you can take a look at these jackscrews to see if one will fit your application.
