Screw Quality
------Question for PMS 632 0025 PH Please Put your question below------
Is there any QC with this item? We have used them and have a 20% failure rate. The quality is shockingly bad.
When you have used these SCREWS with a 20% failure rate for PMS 632 0025 PH MACH SCREW PAN PHILLIPS #6-32 from BFirst Industrial we would suggest a trial 1st. Please try the PMSSS 632 0025 PH as Stainless Steel version if their quality is a better fit.
Thank you. You are right they should be replaced with a better quality screw and scrapped.
