Some common questions we received about the CTM051 Ground Pro Meter from SCS are collected below.
- What is the difference between the SCS CTM051 grounding resistance measuring instrument and a precision multi-meter?
The SCS CTM051 Ground Pro Meter is a comprehensive instrument that measures the ground connection of your equipment in accordance with Grounding standard ANSI/ESD S6.1 and ANSI/ESD S20.20. Measuring ground with a digital multimeter does not comply with ANSI/ESD S20.20 because it measures resistance and not impedance.
- Is there any more information for using CTM051 to provide accurate measurement of ground impedance?
SCS has provided additional instructions for the device here: SCS-Ground-Pro-Meter 2.pptx (4.7 MB)
Applicable part number
SCP264-ND
