SDCard
------Question for ED-IPC3020-08320-P Please Put your question below------
Can you clarify that the 32GB SDCard comes installed?
(it lists that the 8GB is installed, but not the SDCard)
Welocme to the TechForum
This does come with the 32 GB card installed with the 32 in the part number from the ordering code on the datasheet.
ED-IPC3020-datasheet-en.pdf
Thank you
Ryan
:white_check_mark: Thanks for the Quick Reply. Order incoming :slight_smile:
