------Question for SJ-5008-BLACK Please Put your question below------
Please give me Box Size, Box Weight, Box Qty of MOQ 1,040pcs & 3,040pcs?
Greetings,
Dimensions and final package weight will vary at the discretion of the individual packaging the order, and are not available prior to shipment.
The linked datasheet indicates that individual items measuring 0.5" square are presented in pads of 80 pieces in an 8x10 format, which might be expected to weigh on the order of 50 grams or 2 ounces each based on indicated dimensions and typical densities of the indicated polyurethane material.
Understood. Thank you!!
