Siemens ET200 SP Distributed IO Checklist
This is a checklist used to restore connectivity between the Siemens PLC and the ET 200SP.
Difficulty: :gear: Engineer — difficulty levels explained
Last update: 06 Mar 2026
Device Configuration
  • Verify the TIA Portal configuration matches the real-world devices. Pay attention to version:
    • Version of the ET 200SP Interface module.
    • Version of the Server Module. Don’t make my mistake and assign V1.2 when the actual version is V1.12. In this case, the base V1.1 is required by TIA Portal.
    • Version of each of the submodule(s).
Power
Network Connectivity
  • Use the ping command to verify basic network functionality for both the PLC and ET 200 SP.
TIA Portal Configuration
  • Apply the PROFINET device name e.g., io device_1. I’ve included Figure 1 as a reminder as I often forget this step and then wonder why the system diagnostics displays the hardware component not available message.
  • Verify that the TIA Portal configuration matches the real-world port use (e.g., X1 vs X2).
  • Set the partner port (“ANY port” vs PLC specific).
  • Compile and the download the hardware and software.
Figure 1: PROFINET name screen.
Troubleshoot using the PLC’s Diagnostic Data
Figure 2 presents the PLC diagnostics screen for. As part of the troubleshooting process, it is sometimes useful to power cycle the PLC. In this example we see:
  • 12:18:11: Supply voltage missing
  • 12:18:20: Reboot
  • 12:18:28: Hard fault from an AS-i networked device
Figure 2: Diagnostics screen for the PLC.
About This Author
