Slot position
------Question for TS3575SL Please Put your question below------
Is the slot position consistent?
i mean this drawing, 1st slot to the tip and the other 1 is almost in the middle
Hello @judge.mozo,
Thank you for your post.
For these DIN rails they are normally cut off a larger piece and depending on the length you order it may seem like they are at random lengths, but the holes are based off the “original piece” before the manufacturer starts cutting them to length.
Is the slot position for the TS3575SL with a 3-inch length fixed exactly as shown in the drawing?
Hi @judge.mozo
Thank you for your response. The drawing shows the slot and rail dimensions; however, we may not be able to guarantee that the cut will match the drawing exactly.
