Software interface description for new HJ-P3029 LoRa modules
------Question for HJ-P3029_LD-P900
Please Put your question below------
Do you have a datasheet on the SPI communication with these modules?
I have found a manual for the PAN3029 chip but it in Chinese.
The only thing I could locate is the manual in English https://resource.hjsip.com.cn/webDataZh/HJ-P30xx_LD_Hardware%20design%20manual_V1.1_20260115144348A065.pdf
Hi Jeff,
I received a message from the manufacturer with the manual for the PAN3029 chip that the device uses. It is mostly in Chinese.
Attached is the manual and a google translated version it. It is far from perfect but it seems to give enough information that someone could use it to write software.
Kevin
(attachments)
PAN3029_PAN3060_google.pdf (3.87 MB)
PAN3029_PAN3060产品说明书.pdf (2.68 MB)
