------Question for 333140 Please Put your question below------
There is a 3-hole pattern above light L2 but no component included. What is that pattern for?
It looks like just blank holes. No component goes there.
LED Dice Soldering Kit - Learn Electronics with a Fun Project – Soldered Electronics
The circuit board traces go to a pull down resistor that is connected to the microcontroller. They don’t include that resistor in this kit.
Based on where the three pins go this is likely a way to input a switch to trigger it instead of the vibration sensor.
