If you are looking for the pinout of SparkFuns 12986, 12999, and 12877 shift register RGB LEDs. The pinout goes as follows; pin 1 is the data in pin, pin 2 is the VDD pin, pin 3 is ground pin, and pin 4 is Data out pin. Pin 3 will be the longest of the 4 pins on the LEDs.
