Specification clarification
------Question for STX-4235-3/3-N Please Put your question below------
what is the purpose on the 2.60 diameter hole on the front surface of this component. Is it a threaded hole? If for fastening, what size of fastener is recommended?
correction, 2.40 diameter hole
Hi,
Thank you for choosing DigiKey! I do not know the answer to your question right away. However, i have sent a request to the manufacturer of this audio jack and will reply as soon as i have an answer.
Hi,
This is the response from the manufacturer:
The purpose is for fastening to the panel. It is not a threaded hole, but is intended for use with self-tapping screws. M2.5 screws should work.
