------Question for 7840415 Please Put your question below------
I need several thousand feet of this cable. How many feet per spool?
Thanks,
Jeff
Thanks,
Jeff
Hello @dadtown622 ,
Thanks a lot for your query. For the part number 7840415 It seems like that you could specify the length you need in feet, in the quantity tab during your order.
Please note Qty 1pcs = 1FT.
Consider adding the details of your order (e.g. length of each spool) in the order note. Usually If there are any special requirements for your order specified in the order notes, DigiKey will attempt to accommodate it.
I would like to know if I order 2000ft will I get 4 500ft spools? 2 1000ft spools? 2000 1ft cables?
Thanks,
Jeff
Based on what the manufacturer lists on their site for these I would think that the nominal un-cut spool would be 100ft from SAB.
However I would have to asked them to verify if they have longer ones that what seems to be indicated.
I have received a response from the manufacturer.
For the 7840415 the spools they have are 1000foot lengths.
So in your example you should get 2x 1000’ spools.
Thank you! ![]()
