------Question for 2205070-2 Please Put your question below-----Hallo ich benötige nur eine Sorte der Stecker , ist es möglich die auch zu bekommen?
The below were the connectors I had found for each end.
For the cable mount to male contact end I found the A99462CT-ND
7-215083-8 TE Connectivity AMP Connectors | Free Hanging, Panel Mount | DigiKey
For the cable mount to through pin end I found the 17-215570-8CT-ND
215570-8 TE Connectivity AMP Connectors | Board In, Direct Wire to Board | DigiKey
Also, I found the 3M155833-100-ND as an example cable roll.
In case one would want to make a version of the original cable themselves.
