Step file for 0453860000
------Question for 0453860000 Please Put your question below------Can you send me a 3d step file please? Also one for the associated cover PN: 0453660000. Thank you.
Unfortunately 0453860000 is obsolete an Weidmuller no longer hosts the files for it, based on the results of my search. The same applies to part number 0453660000 as well. Sorry for the inconvenience but it’s unlikely that you’ll find anything more detailed than the 2D drawings in this datasheet: https://mm.digikey.com/Volume0/opasdata/d220001/medias/docus/1068/Component%20Carriers%20%26%20Housings.pdf
Thank you for that.
Could you recommend a more modern replacement?
