4110-SNCALS-SNSKTB-ND
why do you guys show that you have the item in stock and then you cancel it from my order. that is the second time you guys do that with the same item why is that ?
This part is from a MarketPlace supplier and is not stocked at DigiKey.
I would suggest contacting orders@digikey.com to see if there is another issue that is causing the cancellation.
