Suitable replacement for 65SA420D
Can you suggest a suitable replacement for 65SA420D?
Hello danr504,
I found a data sheet for XP65SA420DR and used that as a reference. XP65SA420DR-YAGEO.pdf
The closest similar ones to that we have in stock are IPA65R125C7XKSA1 and IPAN60R360PFD7SXKSA1.
Make sure you check them out thoroughly to verify if they can work for your application.
Regards,
