Syntiant V2S200D Flex (KAS-700-0177) and KC20074-A01 – Compatibility, Pinout & FFC Orientation
Hi, I’m planning to purchase several Syntiant components and would like to confirm their compatibility and wiring requirements before placing an order.
Products under consideration:
  1. KAS-700-0177 – V2S200D on Flex
  2. KC20074-A01 – Syntiant Flex Adapter
    DigiKey P/N: 6017-KC20074-A01-ND
  3. KAS-33100-0011 – V2S200D Lite Evaluation Kit
My plan is to use the Lite Evaluation Kit for initial signal acquisition via USB, then interface a standalone V2S200D Flex sensor with an Arduino Nano 33 BLE Sense Rev2 (nRF52840) through its PDM interface.
I have reviewed the available product briefs and application notes, but I would appreciate clarification on a few details.
1. Adapter Compatibility
The DigiKey product page lists the adapter as KC20074-A01, while its linked documentation refers to KCA2733.
  • Are KC20074-A01 and KCA2733 electrically and mechanically equivalent?
  • Is KC20074-A01 directly compatible with the KAS-700-0177 V2S200D Flex sensor?
  • If not, is there a recommended alternative adapter?
2. FFC Pinout and Orientation
According to the KAS-700-0177 product brief, the Flex sensor has six functional contacts: GND, Power, DATA, CLOCK, SELECT, and GND.
  • What is the exact pin mapping between the V2S200D Flex contacts and the KC20074-A01 output terminals?
  • Should the Flex contacts face downward when inserted into KC20074-A01?
  • How can Pin 1 be identified on the connector?
  • How should the adapter’s WS terminal be handled when using the V2S200D in PDM mode?
A schematic, pinout diagram, or connector orientation drawing would be especially helpful.
3. External MCU Integration
I plan to connect the V2S200D to an Arduino Nano 33 BLE Sense Rev2 using its 3.3 V logic and PDM interface.
  • Is KC20074-A01 a passive breakout adapter, or does it contain additional circuitry?
  • Are any external components, such as pull-up/pull-down resistors, decoupling capacitors, or level shifters, required?
  • Is there a recommended reference circuit for interfacing the V2S200D with a third-party MCU?
4. Product Packaging
The KAS-700-0177 product brief mentions a “2 Pack” configuration.
  • Does ordering quantity 1 from DigiKey include one or two V2S200D Flex sensors?
  • Is the V2S200D Flex sensor included in the KAS-33100-0011 Lite Evaluation Kit electrically and mechanically identical to the standalone KAS-700-0177?
Any clarification, documentation, or experience with these components would be greatly appreciated.
Thanks in advance for your help!
