My 1998 Dodge Dakota has a Kelsey Hayes 325 ABS unit in it. Inside of the module is a Siemens T72M5D121-12-16 relay. What is the replacement for this relay as it is discontinued.
Thanks,
Kurt
Hello lohsekurt, welcome to the Forum community! I did not locate an exact equivalent for your relay, but this is a possible substitute you can look at: Z2617-ND This is not an exact equivalent, but a possible substitute. You’ll want to compare datasheets to verify that this substitute is suitable for your application.
