------Question for T92S7D22-22 Please Put your question below------
Does the relay disconnect the voltage when it drops below 22v DC?
Is the relay NO?
Thanks,
Raz
Is the relay NO?
Thanks,
Raz
Hello @raz-m
Welcome to DigiKey TechForum.
Dropping below 22 VDC alone does not make the relay open. The T92S7D22-22 is a Normally-Open (NO) relay, and its coil is rated 22 VDC, The relay opens (disconnect) when the voltage drops below 2.2 VDC.
Page 3 of the below PDF. Table "Coil Versions, DC Coil (D Type).
This shows the information @Idan indicated.
ENG_DS_1308242_T92_A4.pdf (1.7 MB)
