Could you please confirm whether the pins of the following connectors have been assembled? Will these connectors be shipped with the pins already installed?
TC-240-SM-SS-X
TC-195-SM-SS-X
TC-240-SM-SS-X
TC-195-SM-SS-X
Hi,
Thank you for your inquiry. There is no way for the pins to be pre-assembled as they need to be soldered onto the coax prior to installation of the connector. The Datasheet shows the recommended strip dimensions for installing the pin and the connector.
