Tech tip: How to integrate a 24 V PCB mount AC/DC module: fuse, inrush, hold-up and layout
Encapsulated AC/DC modules supply 12 V or 24 V directly from the mains on a PCB, for example in control units, sensors or metering devices. Whether the end product works reliably also depends on the input fuse, the inrush current, the start-up behaviour and the PCB layout. This tip goes through these checks using the Wöhrle WPR-30-24 (24 V / 1.25 A, 30 W) as an example.
1. Check the operating point
  • Input: 90 to 264 V AC, 47 to 63 Hz.
  • Operating temperature: -30 °C to +85 °C with derating. Read the temperature derating curve and the curve “output derating vs. input voltage” before you fix the load current.
  • Several values differ between 115 V AC and 230 V AC. Design for the lowest mains voltage of your markets.
2. Select the input fuse
  • Typical input current: 0.75 A at 115 V AC and 0.5 A at 230 V AC.
  • Cold start inrush current: typ. 25 A at 115 V AC and 45 A at 230 V AC.
  • Plan a time-lag fuse in the line conductor. Its rating must stay clearly above the input current at the lowest input voltage. Check its I²t value against the inrush current and confirm the choice with a measurement on your board.
3. Plan start-up and capacitive load
  • At full load the output appears after up to 1500 ms at 230 V AC (1900 ms at 115 V AC). Make sure that your reset and power sequencing tolerate this delay.
  • The maximum capacitive load is 700 µF. Add up the input capacitors of all downstream DC/DC converters and the bulk capacitors.
  • Overcurrent protection responds at 115 to 160 % of the rated current. The module then works in hiccup mode and recovers automatically. Motors or lamps with high switch-on currents can trigger it.
4. Use the hold-up time correctly
Hold-up time at full load: typ. 40 ms at 230 V AC, but only 10 ms at 115 V AC. At partial load a module usually bridges longer.
5. Lay out the PCB for safety and EMC
  • Class II module with four pins: AC/N, AC/L, -VO and +VO. There is no PE connection.
  • Isolation input to output: 4 kV AC for 1 min. Keep the creepage and clearance distances of your end product standard between primary and secondary copper. Do not route traces under the module that cross from the input to the output side.
  • As a standalone unit the module meets EN 55032 class B for conducted and radiated emissions. The final equipment must still be re-evaluated for EMC.
  • Leakage current below 0.25 mA at 264 V AC. Wave soldering max. 265 °C for 5 s.
Example
A sensor interface needs 24 V / 0.9 A (21.6 W) at 115 V AC and 230 V AC.
  • WPR-30-24: 0.9 A is 72 % of the rated 1.25 A. Check the derating curve at your maximum ambient temperature.
  • Two DC/DC converters with 100 µF each plus 220 µF bulk capacitance give 420 µF. This is below the limit of 700 µF.
  • Does more output capacitance help at 115 V AC (10 ms hold-up)? Assume the DC/DC converters work down to 20 V. Even the full 700 µF store only ½ × 700 µF × (24² - 20²) V² ≈ 0.06 J. At 21.6 W this adds about 3 ms. For longer dips, buffer the critical circuit on the DC side or select a larger module.
Wöhrle WPR modules (24 V) on DigiKey
Wöhrle part DigiKey part number Key data
WPR-15-24 6141-WPR-15-24-ND 24 V / 0.63 A, 15 W, 52.5 x 27.3 x 24 mm, solder pins
WPR-30-24 6141-WPR-30-24-ND 24 V / 1.25 A, 30 W, 69.5 x 39 x 24 mm, solder pins
WPR-30-24-ST 6141-WPR-30-24-ST-ND 24 V / 1.25 A, 30 W, 91 x 39.5 x 28.5 mm, screw terminals
WPR-60-24 6141-WPR-60-24-ND 24 V / 2.5 A, 60 W, 87 x 52 x 29.5 mm, solder pins
WPR-90-24 6141-WPR-90-24-ND 24 V / 3.75 A, 90 W, 85 to 305 V AC input, 87 x 52 x 29.5 mm, solder pins
The series also includes 12 V versions such as the WPR-30-12. Inrush current, hold-up time and capacitive load limits differ between the sizes, so check the datasheet of your module.
How do you size the input fuse for PCB mount power supplies? Questions about a specific board are welcome here.
