Problem Description Summary
Issue Identified: Recent inspections of LED MPN: VSMY98545 have revealed damage and cuts at the left edge of the units.
Observation Details: The damage appears to be an overcut originating from the manufacturing process.
Technical Concerns:
High-Voltage Performance: There is significant concern regarding the impact of these cuts on dielectric strength in high-voltage applications.
Reliability Risks: The overcuts pose a potential risk for internal arcing or mechanical failure driven by thermal expansion.
Current Request: Formal technical assessment is required from the manufacturer to confirm if the units are still functional and reliable for use, or if this condition is considered normal.
