Hi, Im just received my order Briadcom AS22-M560-4T12 incremental encoder. The encounter came with not assembled. It was loose in pieces. I need your help with how to assemble it properly. Furthermore, the cabling with a connector is available to buy it? I’m looking forward to hearing from you soon. Thank
Greetings,
An application note describing the recommended assembly process is available from the manufacturer’s site here.
Page 2 of the datasheet contains information about mating connectors.
Available cable assemblies can be found here. The housings and contacts mentioned are also available individually, as well as pre-crimped individual lead assemblies.
