Technical Inquiry and Availability Request for STEVAL-16GZMAI1 Camera
I have some technical questions:
1. VIS and NIR Operating Modes
  • Does the camera support independent operation in Visible (VIS) and Near-Infrared (NIR) modes?
  • Is it possible to switch between VIS and NIR modes through software commands without restarting the camera.
2. Frame Rate and ROI Configuration
  • What is the maximum achievable frame rate (FPS) at full resolution?
  • Could you provide a table of supported ROI resolutions and their corresponding maximum FPS?
  • Does reducing the ROI size increase the maximum achievable frame rate?
3. Interface and Jetson AGX Orin Integration
  • What additional hardware, adapter boards, cables, or accessories are required to connect the camera to NVIDIA Jetson AGX Orin via MIPI CSI-2 or USB?
  • Are there any available drivers, SDKs, or reference implementations for Jetson platforms?
Hello @nguyenviethunghc2, welcome to the TechForum!
The STMicroelectronics STEVAL-16GZMAI1 (497-STEVAL-16GZMAI1-ND) is in stock.
Below is what the VD16GZ datasheet (DS14163) and VD16GZ S-Board data brief (DB5571) state. For the best support, I recommend contacting ST through the ST Imaging Community.
No separate modes are described. RGB and NIR images are produced by host processing (VD16GZ datasheet, page 3).
Is it possible to switch between VIS and NIR modes through software commands without restarting the camera?
The datasheet states the sensor is fully configurable through I2C and supports frame-to-frame configuration changes (VD16GZ datasheet, page 3).
For more detail on VIS and NIR operation, please reach out to ST through the ST Imaging Community.
88 fps (VD16GZ datasheet, page 4, Table 1).
There’s no full ROI table. The datasheet gives these examples (VD16GZ datasheet, page 13, Table 2):
The examples show higher frame rates at smaller resolutions (VD16GZ datasheet, page 13, Table 2).
  • MIPI CSI-2: 22-pin FFC connector, with a 10 cm ribbon cable included in the kit (S-Board data brief, pages 1 and 3).
The documentation doesn’t cover Jetson hardware.
The STSW-IMG504 driver page on ST names Raspberry Pi and STM32N6 as examples of supported platforms. Jetson is not mentioned, so ST would be the best source to contact about Jetson support.
