------Question for SRCOOL5KWRM42U Please Put your question below------
What low temperature can the unit maintain?
Hello @plavorato,
Thank you for your post.
I do not see a specified temperature mentioned in their documentation, but the manufacturer does have quite a lot more information on their site regarding the performance of that part.
Hello Brent_2328,
Thank you for your quick response. The operating temperature listed tells me that the unit will stop cooling when the ambient temperature is 64°F, and what shuts down at 104°F? I am going by the operation of your typical A/C unit, where the low temperature, usually 61F, is when the unit reduces cooling until the ambient temperature goes above 61F. Is that not the way to look at this?
Thank you again for your help.
Best regards
Pat
The brochure for the item would appear to indicate that the temperature setpoint can be adjusted within a range of 64 to 99°F:
