Temperature values Reliability Calculation for MX25V8035FM1I
------Question for MX25V8035FM1I Please Put your question below------
We were working on the thermal analysis of this particular IC “MX25V8035FM1I” and couldn’t find the junction - ambient temperature (Rth ja) and any other (exact) thermal analysis values, like, Junction to case temperature, case temperature which are necessary for the reliability calculations. it would be nice if u provide those values.
thank u.
Welcome to the forum.
Since this is an 8 pin flash memory chip it should produce a negligible amount of heat itself.
As long as the ambient temperature and applied voltages stay below the maximum spec the part should work normally.
Generally it’s only components that supply or pass significant current that you need to worry about junction temperature separately from ambient temperature.
If you need more information I suggest you contact the manufacturer via the support channels on their website. https://www.macronix.com/
