Terminal Pads
------Question for LL200-2.4-37 Please Put your question below------
Does the PowerFilm LL200-2.4-37 have exposed positive and negative metal contact pads? Can I connect alligator clips directly to these contacts to measure voltage with a multimeter, without soldering?
@Bella Welcome to DigiKey TechForum
About LL200-2.4-37 connection, its tinned foil tape on either side of the module creates functional positive and negative connection points. Burn/scrape through the protective laminate at any point on the foil tape to solder or make a connection. Pre-exposed front or back contact options are available.
But please note that: DO NOT crease, kink, fold, cut, pinch or stretch panels within the active PV area (any area between the positive and negative foil tape). This will cause permanent damage of varying severity.
For more technical information, please refer to
  1. Electronic Component Solar Panel Handling
  2. How to Solder PowerFilm Electronic Component Solar Panels
  3. LL200-2.4-37 Drawing
