The display of caliper flashing problem
The display on the caliper will flash while in operation. Is it normal?
Welcome to the forum.
A good digital indicating caliper does not flash during normal measurement.
Perhaps it’s a low battery warning.
I don’t recognize the instrument, what is the make and model number?
It’s a generic low-cost unit sold under dozens of different names/brands.
The flashing display is indeed a low-battery indication, and the type typically takes an SR44/357 size silver oxide battery that’s inordinately expensive and very frequently dead when one picks up the caliper as a result of a design that “wakes up” whenever the slide is moved, either intentionally or by random vibrations of a surface on which it’s resting.
Maintaining a habit of locking the slide using the screw when the unit is set aside can reduce the need for spare batteries, but having some around should be a standard practice if one desires to use a caliper of this type. Be gentle with the battery door, as it breaks/becomes loose quite easily.
Thank you so much. Since the caliper was only delivered last Friday, I didn’t expect the battery to be low. Anyway, I have replaced the battery, and the flashing has stopped.
