Hi DigiKey Support Team & Community,
I am planning to develop a thermal monitoring system using a Raspberry Pi 5 to detect sudden fire hazards/hotspots in overhead electrical wiring.
I am currently considering the FLIR Lepton 3.5 (Part Number: 500-0771-01). Since this is my first time working with the Lepton series, I would appreciate your guidance on the following points:
Breakout / Carrier Board Recommendation:
What is the most reliable breakout or carrier board to interface the FLIR Lepton 3.5 with a Raspberry Pi 5? (e.g., PureThermal 3, Lepton Breakout Board V2.0, or other DigiKey options?)
Cablings & Accessories:
Are there any specific cables, adapters, or accessories required to ensure a stable connection between the carrier board and the Raspberry Pi 5 (whether via USB or SPI/I2C)?
Alternative Modules:
Are there alternative thermal imaging modules available on DigiKey that might be easier to integrate or better suited for this specific application with a Raspberry Pi 5 compared to the FLIR Lepton 3.5?
Please kindly provide the relevant DigiKey Part Numbers for your recommendations.
Thank you for your support!
