TIPP116 - TO92 - Darlington PNP
Hello i am looking for a replacement for this Transistor as it is now obsolete
Hi Nemesis! Welcome to the forum.
Some good news is that for the TIPP116 (which looks like the full specs are 2 Amp / 80V PNP-Darlington type) I did find some possible options.
For the bad news: I did not show we had anything that was a TO-92 equivalent. The TO-92 has a pitch of ~1.3mm. Everything I am seeing is ~2.5mm pitch spacing.
In case you’re interested, here’s the list I was able to come up with so far: PNP - Darlington Single Bipolar Transistors
Prior to purchasing, I recommend going through any datasheets to qualify any of these options as good alternates for your application.
Best, Regards,
Lindsay
