To develop a reliable 120 kHz ultrasonic transmitter circuit
I am trying to develop a reliable 120 kHz ultrasonic transmitter circuit using the KEMET ND18X3N6 piezoelectric transducer.
Problem: Although the Arduino, TC4420, and IRF540N stages generate the required 120 kHz signal correctly, the waveform becomes weak and distorted when the PZT is connected, indicating an impedance/drive mismatch that needs to be resolved.
Greetings,
Further information about how the circuit is configured and how the described measurements are being made would be helpful.
Seeing that the TC4420 is a single-channel low-side driver however, it seems likely that the circuit is not capable of driving the transducer properly.
Recognizing that the piezo transducer behaves more or less as a capacitor, the final portion of the circuit likely looks a lot like the below. If one’s measures the signal at the junction of the FET and capacitor (piezo), there’s no reason to expect a large signal because the capacitance has nothing other than its own leakage to discharge it.
If this is the case, I’d suggest changing to a half-bridge type of drive arrangement. Driver products such as the MIC4605-1YM-TR are available that provide the necessary additional functions, while allowing control with a single logic line.
@rick_1976 The schematic
That would appear to confirm my suspicions described above. Changing to a half-bridge drive structure would be a recommended solution.
Can you specify which half-bridge we should use here?
See @rick_1976’s suggestion above. He gave you part number MIC4605-1YM-TR.
If you don’t want to have to drive the low and high side MOSFETs independently, then you might consider the related MIC4605-2YM-TR, as a single input controls both the high and low side FETs.
Quick updates:
Circuit works now after removing the mosfet.
Project Progress Report
  1. Work Completed So Far
  • Developed the transmitter circuit using the TC4420 driver IC.
  • Generated an approximately 120 kHz signal using the Arduino UNO.
  • Observed the transmitted signal on the oscilloscope and confirmed that the receiver detects the transmitted wave.
  • Tested the receiver frequency, which showed readings around 118 kHz with minor fluctuations.
  • Tested PLA and GFRP samples between the transmitter and receiver, but the received waveform did not show clear or consistent changes.
  1. Current Problem Statement
The main challenge is to obtain and analyse a reliable received waveform when different material samples are placed betwe
en the transmitter and receiver. The received waveform does not closely resemble the transmitted waveform, and clear differences between the tested materials are not yet visible.
I need guidance on preparing suitable PLA and GFRP test samples, conducting experiments, identifying expected waveform changes, and selecting an appropriate receiver-side circuit or signal-conditioning device to improve waveform detection and enable future identification of cracks, voids, and delamination.
Enclosed video & schematic
