Top eleven Frequently Asked Questions on Analog Devices’ AD5706R, AD5770R and SoftSpan™ series LTC2662 & LTC2672CUH-16#PBF low-noise, four-channel, 16-bit Digital-to-Analog Converters (DACs) designed to generate programmable current outputs
Question 1: What is the suggested power-up sequence for the AD5706R ?
Answer: There is no recommended power-up sequence required for the AD5706R
Question 2: Can I externally connect channels together in current source mode to increase current delivered to the load?
Answer: Yes, any combination of channels (when in current source mode only) can be connected externally, for example you can have 4 X 300mA channels or 2 X 200mA channels, or any combination in between
Question 3: When I connect multiple channels together, how do I program the DAC registers to achieve my required current output ?
Answer: The AD5706R has MULTI_DAC_INPUT_A and a MULTI_DAC_CH_SEL register. Any channels selected in the MULTI_DAC_CH_SEL register will be updated by the value written to the MULTI_DAC_INPUT_A register, meaning one DAC write can be broadcasted to any combination of channels, in this case the channels are externally connected.
Question 4: Is control over LDACB pin required to update the DAC outputs?
Answer: LDACB provides a way to synchronize updates of all DAC outputs via hardware GPIO control. An alternative would be to use the Software LDAC feature of the device via DAC_SW_LDAC register. If being synchronized is not a requirement, each DAC outputs can be updated by direct writing to the DAC_INPUT_A_CHn registers
Question 5: What are main similarities and differences between the AD5706R and the recently released AD5710R ?
Answer: The AD5710R is an 8-CH current-source or a voltage-source DAC with 50mA drive (IDAC & VDAC modes) , with current source/voltage source mode selectable via SPI. The current range per channel is fixed at 50mA and cannot be set to another level via SPI.
The AD5706R is a 4-CH current source only DAC but with multiple current ranges which are SPI selectable, it cannot be configured as a voltage source. However, the max output current per channel is much higher, 300mA.
Question 6: Can the internal reference of AD5706R be disabled?
Answer: Yes, the internal reference of AD5706R is off or disabled by default upon power on. This is to avoid a scenario that an external reference device provides reference setpoint to the VREF while internal reference is enabled.
Question 7: What are the new digital features included in AD5706R as opposed to AD5770R and SoftSpan™ series LTC2662 & LTC2672CUH-16#PBF
Answer: AD5706R comes with the latest ADI enhanced SPI IP, this allows multiple features such as streaming, CRC and interface status for diagnostics. It also has 2 address pins which can be externally connected to IOVDD or AGND, this allows up to four AD5706R’s to share the same SPI bus.
Question 8: I have problem communicating with the device, what should I do?
Answer: Refer to this EngineerZone FAQ.
Question 9: Does AD5706R support Daisy Chain feature?
Answer: The AD5706R does not have daisy-chain, however, it has 2 address pins that allow up to 4 devices to share the same SPI bus. This is superior architecture than daisy chain, as the number of channels can be expanded to 16 (4 X devices sharing the same SPI bus) and each channel can be programmed with the same latency: 16 SCLK cycles in stream mode. Furthermore, think of this feature as offering I²C flexibility with SPI speeds.
Question 10: What is the default state of the eight outputs on power up or after a reset event ?
Answer: The default after power-on (or reset) is for each output to be in shutdown (high-impedance). This is a safe state that ensures no current will flow immediate after power up.
Question 11: Can all channels drive 300mA simultaneously ?
Answer: Yes, the device can operate with 300mA sourced from all four channels simultaneously. Ensure the power dissipation across the AD5706R is kept in a reasonable level to avoid the operating junction temperature hitting the upper range of 125°C. The On-chip temperature sensor can be used to monitor TJ via the MUX_OUT pin.
TSELF_HEATING = (Total_Power * θJA ) °C
TJ = TAMBIENT + TSELF_HEATING
