Need 3 different transistor replacements. Numbers on each one are
K3377 23
J599 1Z
A1244
K3377 23
J599 1Z
A1244
Hello @zac.webb,
The transistors are most likely marked with Japanese Industrial Standards Committee (JISC) numbers.
Knowing this, we can use a few tricks to locate the part within DigiKey:
Add a 2S as a prefix e.g., 2SA1244
Search using a logical AND e.g., “A1244 transistor”.
Tech Tip: Watch out for package type as the base part number often has several different options. For example, TO-251 and TO-252.
Unfortunately, the 2SK3377 and 2SJ599, MOSFETS are listed as obsolete:
The 2SK3377 MOSFET includes direct recommendations as shown in this picture:
The 2SJ599 is harder. We may be able to locate a substitution from this list.
Please reply with the case type of the transistor and MOSFET if you would like additional assistance.
Sincerely,
Aaron
Thanks for your help. Just wondering what is meant by case type and MOSFET in tracking down the last 2SJ599 transistor?
Hi @zac.webb,
As an example, consider this datasheet. This picture shows the difference.
Sincerely,
Aaron
Hi,
Also wondering if I could get some help locating a zener diode C20PH?
Thanks
