Trying to find the correct parts
------Question for TMP-BTAN12-005ASC00A Please Put your question below------
I purchased this connector and I thought I had purchased the other half of this connector but they don’t fit together. Also the nut at the back is missing for gripping on the wire.
What else do I need to purchase to make one connector.
Hello shawns, welcome to the TechForum!
According to the assembly guide and drawing (both found here), the cable clamp parts are considered accessories that come separately. Page 16 (marked 15) of the datasheet shows the recommended parts for securing the cable when using a breakaway type. The datasheet doesn’t mention any jam-nut for the breakaway type (a.k.a. push-pull). The datasheet also implies that the threaded receptacles will work with the push-pull version. These are the mates that should work with this connector. The threaded mates may work with the back shell assembly mentioned on page 15 (marked 14) of the datasheet.
Could you get a parts list together to help me out with this?
